VNXF] Multi Prefix
addon 2.3 VNXF] Multi Prefix 1.0.2
เวอร์ชัน XF ที่เข้ากันได้
  1. 2.3
By default, XenForo has only allowed users to choose one prefix per topic. This has created significant limitations for classified ad forums, resource sharing sites, or sections requiring complex post categorization (e.g., [Selling source code] + [Discount] + [XenForo 2.3]).
To completely solve this problem, VNXF introduces the [VNXF] Multi Prefix Add-on – a groundbreaking solution that breaks through the limitations of topic categorization on XenForo 2.3+.
KEY FEATURES
  1. Multi -Select Prefix: Users can select and combine multiple prefixes simultaneously when creating or editing threads. The Prefix Menu automatically remains open until the user has made their selection.
  2. ⚙️Maximum Prefix Limit: In AdminCP, you can easily limit the "Maximum number of prefixes that can be selected for a post" (e.g., only allow a maximum of 3 tags). The system will block and warn the user directly on the post creation interface if the allowed number is exceeded.
  3. Highly Precise Filtering (Independent Prefix Filtering): Each prefix displayed on the thread list acts as an independent filter. When you hover over or click on any prefix, the system will filter out all posts containing that prefix, ensuring no overlapping links.
  4. Optimized & Compliant with XenForo 2.3 Framework: This add-on is developed in strict compliance with the latest XenForo 2.3 coding standards, without "hacking" the core. It automatically adapts to all custom styles, including complex UI/UX, without breaking the interface.
DEMO
INSTALLATION INSTRUCTIONS
The installation process is extremely simple and straightforward:
  1. Download the attached file.
  2. Go to AdminCP > Add-ons > Install/upgrade from archive .
  3. Select the downloaded zip file and click install. (Alternatively, you can extract the zip file from the upload folder to the forum's root directory).
  4. Go to the left column: Setup > Options > [VNXF] Multi Prefix to configure the desired number of limits.
System requirements
  • XenForo: 2.3.0 or later.
  • PHP: 7.4 - 8.3.
Hopefully, [VNXF] Multi Prefix will help make your forum more flexible and intelligent.
Good luck!
ไม่มีสิทธิ์ดาวน์โหลด
ผู้เขียน
การดาวน์โหลด
การเปิดตัวครั้งแรก
การอัปเดตล่าสุด
การให้คะแนน
0.00 ดาว 0 การให้คะแนน
ไฟล์เพิ่มเติมจาก thxf.org
