[XenGenTr] XFRM Ekstralar sistemi [English]
addon 2.x [XenGenTr] XFRM Ekstralar sistemi [English] 1.0.3
ไม่มีสิทธิ์ดาวน์โหลด
เวอร์ชัน XF ที่เข้ากันได้
  1. 2.2
[XenGenTr] XFRM Extras system
Briefly and the most important feature of the plugin is that you can set limits and limits for download in the Resource Manager field.
For example, the X message cannot download without X likes. As you can download X files daily.
This plugin was inspired by this plugin and developed. It has no connection with the specified plugin.
Ekelenti is already used in this forum.
  • It can update all sources.
  • Can evaluate all sources.
  • See who downloaded the source
  • See the resources downloaded in your profile
  • You can't download the source without reacting
  • Set the number of responses so that you can download resources.
  • Limit the number of files that can be downloaded within 24 hours.
  • Force X message count before resource can be downloaded.
  • It gives the user an information message with a warning.
  • You can get more detailed information about the warning with the help page.
  • A topic from the forum can be added to the alerts, link to the article.
[XenGenTr] RM File download limits features
Special permissions for user groups
Can I see all users who downloaded the relevant resource?
Do not download the file without reacting (liking) the relevant source.
To download a file, it needs to receive XX number of responses.
Only X number of files can be downloaded during the day, 24 hours a day.
In order to download files from sources, there must be XX messages in the forum.
Download your files via the download redirect page.
Managers or personal authorities ;
Can the user see all the resources he has downloaded on his profile?
Can it release updates for all sources?
Can I evaluate all resources and give points and stars?
Can it be downloaded without reacting to the sources?
It should not be affected by the number of reactions limit in order to download the resources.
Do not be affected by the daily file download limit.
In order to download the source, it should not be affected by the message count limit.
General features;
Inform the user why they cannot download a file with visual warning blocks.
Give users more information about alerts by providing a custom link for the block.
If a link could not be added, you can inform users via the help page.
Provide information that the file is being prepared using the download redirect page and the countdown timer.
Special pages for the undownloadable resource that provide information on why it cannot be downloaded,
  • The source must be appreciated.
  • You do not have enough reaction to download the source.
  • You have reached your daily resource download limit.
  • You do not have enough messages to download the resource.
You can manage the colors of the warning blocks.
You can translate all alerts in all languages, so you can inform your users in all languages installed on the forum.
Visual warning blocks;
You can highlight to users what kind of file download permissions they have in the sources area with 4 warning blocks. These blocks are as follows.
  • You have to react
  • Response limit restriction
  • Daily limit restriction
  • Limitation on the number of messages
Again, by assigning a special link to the relevant block for these blocks, you can direct them to a topic or article that you have explained in detail and help them get more information.
If a special link is added for the block, the help page will be activated and you can inform the user about this warning, even if it is brief.
From now on, everything is up to your imagination and mind. You can now have this add-on by thinking about what you can use these functions for.
[XenConcept] Next Previous
addon 2.3  [XenConcept] Next Previous  2.2.1
[MMO] Rename Attachments
addon 2.x  [MMO] Rename Attachments  2.1.3
  • Like
ปฏิกิริยา: emon
ผู้เขียน
การดาวน์โหลด
1
การเปิดตัวครั้งแรก
การอัปเดตล่าสุด
การให้คะแนน
0.00 ดาว 0 การให้คะแนน
ไฟล์เพิ่มเติมจาก thxf.org
อัปเดตล่าสุด
  1. 1.0.3 BattleKing enhanced
    BattleKing enhanced Downloads left will be shown if user has the right to Time range of...
