ประกาศ vBulletin 3.8.4 PL1, 3.7.6 PL1 and 3.6.12 PL2 Released
vBulletin 3.8.4 PL1 / 3.7.6 PL1 / 3.6.12 PL2
An XSS flaw within the user profile page has recently been discovered. This could allow an attacker to carry out an action as a user or obtain access to a user's account. To resolve this issue, it has been necessary to release a patch level version of the active versions of vBulletin.
The upgrade process is the same as previous patch level releases - simply download the patch from the Members Area, extract the files and upload to your webserver, overwriting the existing files. There is no upgrade script required.
As with all security-based releases, we recommend that all customers upgrade as soon as possible in order to prevent any potential damage resulting from the flaw being exploited.
Upgrading from 3.8.4, 3.7.6 or 3.6.12
If you are already running the latest version of the 3.6, 3.7 or 3.8 branch, the process you will be required to follow to make your board immune to this flaw is very simple.
There is no need to run an upgrade script if you are already running the latest version.
Visit the Patches section of the vBulletin Members' Area and download the patch for the version you are using, then extract the files from the archive you downloaded, then upload the files to your board via FTP etc., overwriting the existing files. This will update your version to the PL1 release.
Upgrading from an earlier version
If you are not already running the latest version of 3.6, 3.7 or 3.8, you should download the latest version from the Members' Area and perform an upgrade as normal.
Full instructions for upgrading vBulletin are available here.
Download vBulletin 3.8.4 PL1 / 3.7.6 PL1 / 3.6.12 PL2
As usual, the version released today is available for all customers with valid, active licenses to download from the vBulletin Members' Area.
vBulletin Members Area
More...
กระทู้ที่คล้ายกัน
  • บทความ บทความ
vBulletin 6.1.0 Changes and Updates A preview release of vBulletin 6.1.0 is available for download. Preview releases are for testing upcoming releases and should not be used on production servers...
  • บทความ บทความ
vBulletin 6.0.6 is now available for download by self-hosted (download) customers. vBulletin Cloud sites will be automatically updated in the upcoming weeks. Front End Changes Calendar Module...
  • บทความ บทความ
The API functionality of vBulletin 6 and 5.7.5 has been found to have security issues. We have created fixes for these issues. To maintain site security, you should apply this patch as soon as...
  • บทความ บทความ
vBulletin 6.0.4 is now available for download customers. vBulletin Cloud customers will be automatically upgraded over the coming weeks. Home Node Permissions Handling the channel permissions of...
  • บทความ บทความ
This patch solves three issues: how the system detects PHAR files, a potential security issue in BBCode rendering, and a problem with inviting members to a Blog. Self-hosted customers should apply...
